[mapguide-users] Invoke URL in MapGuide Studio
Andrew DeMerchant andrew.demerchant at gemtec.ca
Tue Nov 6 12:55:29 EST 2007
I use it all the time - but I've only ever used it with 1 layer. I just
tested it with 2 layers, and I have the same problem you do. I'm using
MapGuide OS 1.02 though....
Andrew
Chris Tallman wrote:
> Ok does no one else have this problem?  Is it just not used enough to
> care?  Seems like it would be used all the time.  Only having a
> command enabled when specific feature layers are selected.  Is there a
> work around that people are using?
> Any help would be great.
> Chris
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Chris
> Tallman
> *Sent:* Monday, November 05, 2007 8:02 AM
> *To:* MapGuide Users Mail List
> *Subject:* RE: [mapguide-users] Invoke URL in MapGuide Studio
> I am having this same problem.  I have an Invoke Script that I only
> want active when features on certain layers are selected.  This works
> great when only one layer is in the "Use only these Layers:" box, but
> as soon as a second or more layers are added to the list the command
> doesn't enable.  This is pretty easy to reproduce just add multiple
> layers to the list.
> Has anyone else seen this?  Or does anyone have it working with
> multiple layers in the list?
> Chris
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Tuesday, October 30, 2007 8:15 AM
> *Subject:* Re: [mapguide-users] Invoke URL in MapGuide Studio
> In Studio, check the "Additional Parameters" for the Invoke URL
> command...it's on the same tab as where you enter your url. Do you
> have both of those layers entered in the "use only these layers" field?
> Andrew
> alba wrote:
>> Hi all,
>> in MapGuide Studio I have a URL to invoke as:
>> http://www.nabble.com/file/p13483981/invoke.jpg
>> when I use one layer ex. MONUMENTI the command is abled when I select a
>> object on layer MOMUNEMTI,
>> but I use two layers, as image, the command is disabled when I select a
>> object on layer MOMUNEMTI or ZONE DI PIANO.
>> why?
>> thank Alba
> 	*Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
