[mapguide-users] Load Procedures via a script examples?
    Jim O'Leary
    joleary.public at gmail.com
    Wed Nov  7 13:41:11 EST 2007
Thanks for the tips, Bill. I have used the sample code in the Studio API help
to create such a load procedure executable. However, would it not be easier
if you could create a load procedure in Studio and then call it
programmatically? Then you could change the load procedure and the call
would still work. I don't see any calls in the Studio API that let you call
an existing load procedure this way.
Thanks.
Bill Dhimitri wrote:
> Scott,
> I think you are asking about using the MG Studio API that allows you to
> programmatically load an SDF, SHP, DWF, or raster file directly to a MG
> server.
> I have pasted some code below to show a simple example of how to use
> this API.  Just to clarify, the Studio API allows you to create a
> package (.mgp) file (via the PackageWriter class).  That's not what I am
> talking about.  I am talking about classes like SdfLoadProcedure and
> ShpLoadProcedure.  These classes do not create .mgp files.  Instead,
> they provide a programmatic way to do what the MG Studio Load Procedure
> UI's let's you do.
> Note that if you use the Studio API, you must place your .exe file into
> the MG Studio installation folder and run it from there.  Otherwise,
> your .exe file will not be able to load/run the necessary DLLs, and you
> will get an error message at run time stating that a module/file could
> not be found.
> Bill
>         using Autodesk.MapGuide.Studio.Load;
>         using Autodesk.MapGuide.Studio.Site;
>         void Test()
>             LoadSdfFile("C:\\parcels.sdf");
>         void LoadSdfFile(string sdfFilePath)
>             SiteManager siteManager = SiteManager.GetInstance();
>             ConnectionStatus connStatus;
>             SiteConnection siteConn = siteManager.CreateConnection(
>                 "http://localhost/mapguide",
>                 "Author", "author", out connStatus);
>             if (connStatus != ConnectionStatus.Success)
>                 return;
>             SdfLoadProcedure sdfLoading = new SdfLoadProcedure();
>             sdfLoading.SourceFiles.Add(sdfFilePath);
>             sdfLoading.RootPath = "Library://Test";
>             sdfLoading.Execute(siteConn);
> -----Original Message-----
> From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
> Sent: Wednesday, August 09, 2006 1:05 PM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] Load Procedures via a script examples?
> Hi Scott,
> I'm not entirely sure what you're asking.
> I put up a couple sample scripts for making packages from existing
> server-side resources, and loading the same.  Is that what you're
> looking for?
> http://tinyurl.com/qesur
> I don't think that anyone has figured out how to build packages
> externally to Autodesk MapGuide Studio yet.
> My current plan is to load the initial packages through Studio, and then
> use FME (there is SDF support in 2006GB) to refresh the data source
> directly in the repository.
> Jason
> From: Scott Reisdorf [mailto:reisdorf1 at llnl.gov]
> Sent: Wednesday, August 09, 2006 09:33
> Subject: [mapguide-users] Load Procedures via a script examples?
> Does anyone have examples of executing a Load Procedure (i.e. loading
> data from an XML file) via a script?
> I cant seem to find any examples in the Dev Guide on how to do this.
> Any sample code would be of assistance.
> Thanks,
> -scott
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/Load-Procedures-via-a-script-examples--tf2079844s16610.html#a13633212
