[mapguide-users] FDO installation
Eric123 erictsn at cadbeyond.com
Thu Nov 8 05:34:27 EST 2007
Hi All,
I did followed the guide
(http://wiki.osgeo.org/index.php/Building_Mapguide_on_Ubuntu_7.10_Server) to
install MGOS. It seems there have something error when I go to install FDO
(./build_thirdparty.sh > build_thirdparty.log). I did captured the last few
message as below. Anyone can tell me, what is it? Do I made anything wrong?
Thanks in advance.
libs/serialization/src/binary_wiarchive.cpp:28:   instantiated from here
./boost/archive/basic_binary_iprimitive.hpp:87: warning: unused variable 'i'
./boost/archive/basic_binary_oprimitive.hpp: In member function 'void
boost::archive::basic_binary_oprimitive<Archive, Elem, Tr>::save(bool) [with
Archive = boost::archive::binary_woarchive, Elem = wchar_t, Tr =
std::char_traits<wchar_t>]':
libs/serialization/src/binary_woarchive.cpp:28:   instantiated from here
./boost/archive/basic_binary_oprimitive.hpp:87: warning: unused variable 'i'
configure: WARNING: SSL disabled, you will not be able to use HTTPS, FTPS,
NTLM and more.
configure: WARNING: Use --with-ssl, --with-gnutls or --with-nss to address
this.
configure: WARNING: disabling built-in manual
ar: creating ../libcrypto.a
ar: creating ../libssl.a
s_socket.c: In function 'do_server':
s_socket.c:288: warning: 'accept_socket' may be used uninitialized in this
function
make[1]: *** No rule to make target `gdal/lib/libgdal.so.1.11.3', needed by
`all-am'.  Stop.
make: *** [install-recursive] Error 1
root at xen2:/etc/subversion/fdosvn#
View this message in context: http://www.nabble.com/FDO-installation-tf4770164s16610.html#a13644665
