[mapguide-users] Re: Sheboygan Dataset - Different Format
Darren Cope
darrencope at gmail.com
Sun Nov 11 19:17:52 EST 2007
Hi Andy,
Thanks for trying--yes, I realize that using MG6.5 is a bit backwards,
but we are currently heavy users of it, and would have to make the
switch to MGOS slowly, so it will be around for a while still! Is
there any chance you could try dumping to a shapefile since SDF2
didn't work? Does anyone else have any ideas?
Cheers,
Darren
Date: Fri, 9 Nov 2007 10:49:26 -0800
Subject: RE: [mapguide-users] Sheboygan Dataset - Different Format
To: "'MapGuide Users Mail List'" <mapguide-users at lists.osgeo.org>
Message-ID: <000e01c82301$421dd550$96f1fea9 at SPINAJM>
Content-Type: text/plain; charset="US-ASCII"
Using MapGuide 6.5 seems a bit backwards these days....... I tried to run
the SDF 3 file through FME to convert to SDF 2 and it errored out and would
not complete the translation. I don't have time to track the problem any
further, but thought I'd let you know that I gave it a shot.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Darren Cope
Sent: Friday, November 09, 2007 10:13 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Sheboygan Dataset - Different Format
Hi all,
I'm hoping to use the Sheboygan dataset that is frequently used in MGOS in a
demo, but require the data in SDF 2 format, rather than SDF 3 (the demo will
be running in MG6.5 at this point, as we aren't yet ready to move to MGOS
fully) I've converted all of the layers to SDF2 using FDO2FDO except for
the parcel layer, which throws an error. I was curious if anyone here had
the Sheboygan parcels in a format other than SDF 3 that they could provide
me?
On a related note, are there any use restrictions on the Sheboygan data for
demo site purposes?
Cheers,
Darren
