[mapguide-users] Adding marker on the fly with tooltip
Jackie Ng
jackie.ng at aecsystems.com.au
Mon Nov 12 07:53:49 EST 2007
The tooltip is just html content. Have you tried using the special html
characters (eg. " etc)
- Jackie
Kencana wrote:
> Hi Jackie,
> I have one doubt. I was wondering, why i can't put special character in
> the tool tip e.g. !@#$ and the white space as well. any idea on how to
> solve this?
> Thank you
> Regards,
> Kencana Kesuma
> Jackie Ng wrote:
>> What I mean is that the xml fragment you specified does not constitute a
>> layer definition document.
>> Therefore there must be some kind of "outer" xml document that that
>> fragment would have be merged with to form a valid layer definition
>> document.
>> Looking at the php code (and I'm just grabbing thin air here). I'm
>> guessing $factory->CreateLayerDefinition() is where the outer xml
>> document comes from. So take a look at that function, as that is probably
>> where you insert your tooltip tag.
>> - Jackie
>> Kencana wrote:
>>> Hi Jacky,
>>> Thanks for the reply.
>>> I don't quite understand what you mean by outer xml. anyway, this is
>>> what i did for drawing the marker. also I have attached 1 layer
>>> definition file, templ file, and also the layerdefinition.php file (the
>>> file consists the function in drawing the marker based on the xml file).
>>> I hope you can help me out. And I am really appreciate that.
>>> Thank you
>>> Regards,
>>> Kencana Kesuma
>>> $factory = new LayerDefinitionFactory();
>>> // Create a mark symbol
>>> $resourceId = 'Library://Migrated Files/Stars.SymbolLibrary';
>>> $symbolName = 'Red';
>>> $testing = 'Test 123';
>>> $width = '25'; // points
>>> $height = '25'; // points
>>> $color = 'FFFF0000';
>>> $markSymbol = $factory->CreateMarkSymbol($resourceId, $symbolName,
>>> $width, $height, $color);
>>> // Create a text symbol
>>> $text = "ID";
>>> $fontHeight="12";
>>> $foregroundColor = 'FF000000';
>>> $textSymbol = $factory->CreateTextSymbol($text,
>>> $fontHeight, $foregroundColor);
>>> // Create a point rule.
>>> $legendLabel = 'trees';
>>> $filter = '';
>>> $pointRule = $factory->CreatePointRule($legendLabel,
>>> $filter, $textSymbol, $markSymbol);
>>> // Create a point type style.
>>> $pointTypeStyle = $factory->
>>> CreatepointTypeStyle($pointRule);
>>> // Create a scale range.
>>> $minScale = '0';
>>> $maxScale = '1000000000000';
>>> $pointScaleRange = $factory->CreateScaleRange($minScale,
>>> $maxScale, $pointTypeStyle);
>>> $featureName = 'PointSchema:Points';
>>> $geometry = 'GEOM';
>>> $layerDefinition = $factory->
>>> CreateLayerDefinition($featureSourceName, $featureName,
>>> $geometry, $pointScaleRange);
>>> // Add the layer to the map
>>> $newLayer = add_layer_definition_to_map($layerDefinition, "Points",
>>> "Points of Interest", $sessionId, $resourceService, $map);
>>> add_layer_to_group($newLayer, "Analysis", "Analysis", $map);
>>> Jackie Ng wrote:
>>>> Do you have an "outer" xml template that you are merging this with? If
>>>> so, that's the one where you'll have to place the <ToolTip> tag under.
>>>> - Jackie
>>>> Kencana wrote:
>>>>> Hi Jacky,
>>>>> Thank you for the reply.
>>>>> Anyway I can't find the geometry tag under the marksymbol.templ.
>>>>> this is what i have in markersymbol.templ
>>>>> <W2D>
>>>>> <Unit>Points</Unit>
>>>>> <SizeContext>DeviceUnits</SizeContext>
>>>>> <SizeX>%s</SizeX>
>>>>> <SizeY>%s</SizeY>
>>>>> <Rotation>0</Rotation>
>>>>> <MaintainAspect>true</MaintainAspect>
>>>>> <W2DSymbol>
>>>>> <ResourceId>%s</ResourceId>
>>>>> <LibraryItemName>%s</LibraryItemName>
>>>>> </W2DSymbol>
>>>>> <FillColor>%s</FillColor>
>>>>> <LineColor>FF000000</LineColor>
>>>>> <TextColor>FF000000</TextColor>
>>>>> <ToolTip>test 123</ToolTip>
>>>>> </W2D>
>>>>> I did make some changes to the LayerDefinition-1.0.0.xsd and the error
>>>>> message has gone. however,
>>>>> i can't see the tool tip when i mouse over the marker.
>>>>> any idea of this?
>>>>> anyway i am still using mapguide opensource 1.1.0.
>>>>> because the new version (1.2) the marker is not shown on the map.Have
>>>>> mentioned about this issue in this forum, but so far I havent see any
>>>>> solution for it yet.
>>>>> Thank you
>>>>> Regards,
>>>>> Kencana
>>>>> Jackie Ng wrote:
>>>>>> Did you put the tooltip tag in the right location? The <ToolTip> tag
>>>>>> usually follows the <Geometry> tag in a layer definition document.
>>>>>> - Jackie
>>>>>> Kencana wrote:
>>>>>>> Hi,
>>>>>>> Can we modify the markersymbol.templ file to add <ToolTip></ToolTip>
>>>>>>> tag into it?
>>>>>>> I have try to add it but it returns me such error message.
>>>>>>> ERROR: The new XML document is invalid.
>>>>>>> .PHP Warning: Element W2D content check failure in C:\Program
>>>>>>> Files\MapGuideOpenSource\WebServerExtensions\www\CAN MAP
>>>>>>> Files\layer_functions.php on line 27 PHP Fatal error: Call to a
>>>>>>> member function SetGroup() on a non-object in C:\Program
>>>>>>> Files\layer_functions.php on line 66
>>>>>>> any idea on how i can make it work?
>>>>>>> Thank you
>>>>>>> Regards,
>>>>>>> Kencana Kesuma
>>> http://www.nabble.com/file/p13699701/LayerDefinition-1.0.0.xsd
>>> http://www.nabble.com/file/p13699701/layerdefinitionfactory1.php
>>> http://www.nabble.com/file/p13699701/marksymbol.templ marksymbol.templ
View this message in context: http://www.nabble.com/Adding-marker-on-the-fly-with-tooltip-tf4788633s16610.html#a13705097
