[mapguide-users] OnMapLoaded
ruivilanova
rui.vilanova at gismedia.pt
Wed Nov 14 07:31:37 EST 2007
Well, this is the code I have:
var initTimer;
var viewer;
var showtime;
var scale;
function InitDocument()
initTimer = setInterval(DelayedInit, 400);
function DelayedInit() {
try {
viewer = ViewerFrame.mapFrame;
if(viewer.mapInit) {
clearInterval(initTimer);
showtime=window.setInterval(escala, 300000);//5minutes
ViewerFrame.mapFrame.OnMapLoading = function(e)
//reset timer
clearInterval(showtime);
catch(e) {}
function escala()
scale=ViewerFrame.mapFrame.GetScale();
Now the explanation:
I wanted to call any viewer api function, everytime the map is inactive at 5
minutes, in order to keep the mapguide session alive.
If user makes the map load again, that timer would be restarted. I'm testing
this solution yet.
Could you give me some hints? Do you think it's possible? Remember, call an
api function only when the map is inactive at 5 minutes.
Cheers
Rui
macieksk wrote:
> Hi.
> what did you whant to do?
> 1. Use loading image when map is loaded?
> write someting more.
> ruivilanova pisze:
>> Hi all,
>> does anyone know how to use onMapLoaded event?
>> Thanks in advance
>> Rui
> Maciej Skórczewski
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/OnMapLoaded-tf4804147s16610.html#a13745905
