[mapguide-users] national coordinate system in MapGuide
John Pulles john.pulles at geodan.nl
Wed Nov 14 08:24:39 EST 2007
Hi list,
I am trying to use MapGuide as a WMS server, but so far only managed to
publish a layer using lat-lon coordinates (EPSG:4326). This was for a
feature layer stored in PostGIS with a SRS of 28992 (Dutch RD
projection). That layer can be requested in MapGuide for EPSG:4326 but
not for EPSG:28992.
The exception returned said:
"<ServiceExceptionReport version="1.1.1">
<ServiceException code="InternalError">
The coordinate system conversion failed.
Unsupported coordinate system code. Coordinate system named
Netherlands-RD-New does not exist.<details>The coordinate system
conversion failed.
Exception occurred in method
MgCoordinateSystem.ConvertCoordinateSystemCodeToWkt at line 972 in file
c:\build_bond_area\bond_nightly\build_41.3\ent\os\common\geometry\CoordinateSystem/CoordinateSystem.cpp
</details>
</ServiceException>
</ServiceExceptionReport>"
Does MapGuide server support other coordinate systems than EPSG:4326,
and if this is the case, how should the service or server be configured
to use it? Does it perhaps require manual editing of
OgcWmsService.config.awd?
Kind regards,
John.
John Pulles
Geodan IT b.v.
Buitenhaven 27-A
5211TP 's-Hertogenbosch
Tel: +31 (0)73 - 692 5151
Fax: +31 (0)73 - 692 5150
Postadres / mailing address
President Kennedylaan 1
1079MB Amsterdam
E-mail:  john.pulles at geodan.nl
Website: http://www.geodan.nl
