[mapguide-users] Is it really not possible?
    Traian Stanev
    traian.stanev at autodesk.com
    Thu Nov 15 21:34:15 EST 2007
DWF output does not necessarily have better quality than image output in MapGuide, as long as the image is generated at the one desired scale/dpi.
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joel Carranza
Sent: Wednesday, November 14, 2007 4:20 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Is it really not possible?
If the goal is to produce high-quality output for printing purposes, why not
just use DWF output?
simon hope wrote:
> Hi Scott,
> Please see this thread from a while back:
> http://www.nabble.com/Producing-High-Resolution-images-using-rendering-service-tf3962171s16610.html#a11244745
> Cheers
> Simon
> Scott Hameister wrote:
>> Is it really not possible to set the DPI the Rendering Service API uses?
>> So
>> only FCGI calls can do this? This seems almost ludacris.can anyone
>> explain
>> why an FCGI call would have more options in it than the actual systems
>> API?
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Is-it-really-not-possible--tf4799163s16610.html#a13756625
