[mapguide-users] Building an intelligent tooltip
uXuf
yousuf.hassan at gmail.com
Mon Nov 19 20:19:06 EST 2007
Hi guys,
I am trying to build a tooltip that contains data from multiple tables
(essentially - a join). I have a point layer that gets populated from an
ODBC source. The table has a relatively simple structure: PointID,
PointName, PointLat, PointLon and PointTypeID. Now this PointType is a
foreign key into a Types table which contains only the TypeID and TypeName
fields. What I'd like is the tooltip to resolve the PointTypeID and get the
TypeName to display.
I tried feature-joining the ODBC Source with itself (figures since both the
tables are in the same db), and created a new Extended class (named
PlaceType). This extended class has its primary feature class as the Points
table (or Default:points) and the secondary feature class as the Types table
(Default:types). I then specified for join the PointTypeID column and the
TypeID column.
Now when I reselect the feature source (in an effort to update the Feature
Class dropdown list) I DO get the Default:PlaceType class, but if I select
it I lose all my geometry fields. This extended class apparently does not
pick up the Lat and Lon columns from the original tables, it only picks up
the PointID and PointName columns. So basically in an effort to get a join I
lose my geometry fields.
Any insights into this or would I have to add *yet* another layer with only
tooltips and no points?
Probably a better solution would be to allow SQL type expressions in the
expression builder, a bit reminiscent of MG 6.x.
Regards,
uXuf
View this message in context: http://www.nabble.com/Building-an-intelligent-tooltip-tf4840591s16610.html#a13849076
