[mapguide-users] Mapguide not support MySQL
Сафонов Алексей
alex-saf at npc.vrn.ru
Thu Nov 22 06:43:19 EST 2007
Hi!
Сolleagues,
I have problems with execution "./configure - enable-optimized".
Directly the command is carried out normally. But the deduced message speaks that MySQL is not supported. If to execute a command "rpm-qa | grep mysql" it is visible, that the package mysql-devel is established. Nevertheless I cannot achieve support MySQL. Except for MySQL, others programs: xerces, sqlite, ogdi are not supported, though packages devel for these programs are established in system.
As to me to adjust system so that MySQL it began to be supported?
I ask to help.
OS: Fedora 8 (RedHat)
Thanks,
Safonov A.M.
GDAL is now configured for i686-pc-linux-gnu
Installation directory: /usr/local/mapguideopensource
C compiler: gcc -O2
C++ compiler: g++ -O2
LIBTOOL support: yes
LIBZ support: external
GRASS support: no
CFITSIO support: external
PCRaster support: internal
NETCDF support: yes
LIBPNG support: external
LIBTIFF support: external
LIBGEOTIFF support: internal
LIBJPEG support: external
LIBGIF support: external
OGDI support: no
HDF4 support: no
HDF5 support: yes
KAKADU support: no
JASPER support: yes (GeoJP2=no)
ECW support: no
MrSID support: no
CURL support (wcs): yes
POSTGRESQL support: yes
MySQL support: no
XERCES support: no
ODBC support: yes
PGEO support: yes
OCI support: no
SDE support: no
DODS support: no
SQLite support: no
DWGdirect support no
PANORAMA GIS support: no
INFORMIX DataBlade support:no
GEOS support: yes
Statically link PROJ.4: no
Traditional Python: yes
NG SWIG Bindings:
enable OGR building: yes
rpm -qa | grep mysql
mysql-connector-odbc-3.51.14r248-2.fc8
libdbi-dbd-mysql-0.8.2-1.2.fc8
php-mysql-5.2.4-3
mysql-server-5.0.45-4.fc8
mysql-5.0.45-4.fc8
mysql-libs-5.0.45-4.fc8
mysql-devel-5.0.45-4.fc8
rpm -qa | grep xerces
xerces-c-devel-2.7.0-6.fc7
xerces-j2-2.7.1-7jpp.2
xerces-c-2.7.0-6.fc7
rpm -qa | grep sqlite
mono-data-sqlite-1.2.4-2.fc8
sqlite-3.4.2-3.fc8
sqlite-devel-3.4.2-3.fc8
rpm -qa | grep ogdi
ogdi-3.2.0-0.5.beta1.fc7
ogdi-devel-3.2.0-0.5.beta1.fc7
