[mapguide-users] javascript permission denied problem
Ivan Milicevic
Ivan.Milicevic at supranet.hr
Mon Nov 26 02:43:07 EST 2007
It' not possible due to security reasons. I tried same thing couple months ago... Give up.
From: mapguide-users-bounces at lists.osgeo.org on behalf of Kencana
Sent: pon 26.11.2007 5:01
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] javascript permission denied problem
Hi all,
Currently I try to embed the map to a web portal's frame (which is hosted at
different server), what I am trying to do is to call the javascript function
i have created in the task frame. however, When I called the javascript
function, it gave me "Permission Denied" Error. I also have read about the
cross domain issue in javascript, but is there any solution for this? I mean
is that mean, the web portal must be hosted in the same server with the map
guide web server to make things work?
Hope you guys get what I am trying to explain.
Thank you
Regards,
Kencana Kesuma
View this message in context: http://www.nabble.com/javascript-permission-denied-problem-tf4872795s16610.html#a13943511
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071126/2108f692/attachment.bin
