[mapguide-users] Get Coordinates
Minh Quân quandx at gmail.com
Mon Nov 26 22:09:25 EST 2007
HI Jhonn Jairo Vesga Cadena
I have a solution for this problem.
You can see and try with this.
            string str2 = "";
            for (int i = 0; i < map.GetLayers().GetCount(); i++)
                   MgLayer layer = (MgLayer)map.GetLayers().GetItem(i);
                    MgResourceIdentifier ad = new MgResourceIdentifier(
layer.FeatureSourceId);
                    MgSpatialContextReader spatialReader =
featureService.GetSpatialContexts(ad, true);
                    while (spatialReader.ReadNext())
                        str2 = spatialReader.GetCoordinateSystemWkt();
                    Response.Write(str2);
                    spatialReader.Close();
This c# stuff work fine.
If you have any problem, don't be heritage to write to me.
Cheers,
Quandx
On 26/11/2007, Jhonn Jairo Vesga Cadena <jjvesga at gmail.com> wrote:
> Hi, i have a map in autodesk studio 2007, and i need to solve this issue:
> I need to create a point begins by click on the map, when i click the
> application launch a window where i get the X and Y coordinate, the
> problem its that, how can i get that coordinate??
> Some ideas??
> Thanks
> att:
> Móvil:
> Movistar: 316-524-4147
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Đỗ Xuân Quân
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071127/94102f5e/attachment.html
