[mapguide-users] javascript permission denied problem
Ismael Cams
mapguide2007 at gmail.com
Tue Nov 27 07:46:01 EST 2007
Hello,
if you are working with the Apache webserver you could solve the problem by
using reverse proxy.
Ismaël
Kencana wrote:
> Hi all,
> I heard that, cross domain scripting can be done by doing some proxy
> settings, is that possible?
> Thank you
> Regards,
> Kencana Kesuma
> Ivan Milicevic-3 wrote:
>> It' not possible due to security reasons. I tried same thing couple
>> months ago... Give up.
>> ________________________________
>> From: mapguide-users-bounces at lists.osgeo.org on behalf of Kencana
>> Sent: pon 26.11.2007 5:01
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] javascript permission denied problem
>> Hi all,
>> Currently I try to embed the map to a web portal's frame (which is hosted
>> at
>> different server), what I am trying to do is to call the javascript
>> function
>> i have created in the task frame. however, When I called the javascript
>> function, it gave me "Permission Denied" Error. I also have read about
>> the
>> cross domain issue in javascript, but is there any solution for this? I
>> mean
>> is that mean, the web portal must be hosted in the same server with the
>> map
>> guide web server to make things work?
>> Hope you guys get what I am trying to explain.
>> Thank you
>> Regards,
>> Kencana Kesuma
>> View this message in context:
>> http://www.nabble.com/javascript-permission-denied-problem-tf4872795s16610.html#a13943511
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/javascript-permission-denied-problem-tf4872795s16610.html#a13970173
