[mapguide-users] Mapguide V 2.0
Dave Wilson
dave.wilson at autodesk.com
Wed Nov 28 15:09:06 EST 2007
The php-cgi extension on the mapagent is for the index.html pages which seem to have a problem with the isapi on some API. Although I'm not clear on a .NET install using PHP for the pages.
Aside from "allowing" the php extension you also have to enable the .NET one as well if you haven't already.
There is a defect logged against MapGuide Enterprise on this already so I'm thinking it may also fix open source.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Tallman
Sent: Wednesday, November 28, 2007 1:02 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Mapguide V 2.0
Well I was to fast to the email on this one. I still have some problems but I'm not sure they are Mapguide Related.
I can get to the login page now. However when I type in the username and password I get a 403.1 Forbidden: Execute access is denied error. Pertaining to ISAPI and CGI. I have to figure out what setting to change or add to get past this.
All the directories say scripts and executables so I'm not sure what the hang up is.
If anyone has any ideas I'm listening.
Thanks,
Chris
Sent: Wednesday, November 28, 2007 2:36 PM
That was what I might have miss understood what Dave was talking about.
I added .php with the two files to the Web Service Extensions list and now it works.
Is this an item that should be added to the trac list to make sure it gets fixed in the next release?
Thanks for the help.
Chris
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of IT-Joe Marvin
Sent: Wednesday, November 28, 2007 2:29 PM
Did you check to see if the IIS6 Web Server Extensions is blocking the PHP? Maybe flip on the allow all ISAPI extensions to see if it is blocking it.
-joe
Sent: Wednesday, November 28, 2007 11:23 AM
Yep I'm using Windows 2003.
After the install I have .php set to php5isapi.dll. for the Mapguide VD. This is how it was and it doesn't work.
After your email I added .php set to php-cgi.exe for the mapagent VD. This doesn't seem to fix the issue.
Why am I adding a php ref to the mapagent directory when the admin is in the mapadmin folder which in my case after installation isn't a Virtual Directory(VD)
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Wednesday, November 28, 2007 12:58 PM
What platform are you installing on?
It's likely under IIS6 (Windows 2003) that the web extension for PHP is missing. I have added an entry for the phpisapi5.dll and the php-cgi.exe.
Regardless of your install platform, under the mapagent virtual directory configuration add .php as an extension and point it to the php-cgi.exe.
Note if you check the configuration under mapguide to ensure that .php is pointing to the isapi dll you may get prompted to propagate a script setting to the mapagent directory. DON'T select the mapagent directory and let it propagate, just lick ok.
Regards,
Dave
Sent: Wednesday, November 28, 2007 10:22 AM
Subject: [mapguide-users] Mapguide V 2.0
Has anyone else had an issue with the bundled IIS .NET install and the mapadmin login? For some reason or another the php pages don't want to load. I've installed on a computer where MapGuide has worked before and have also tried the install on a fresh system.
I've been able to check the mapagent index.html page and everything works fine there, so something is up with the php parts.
So is there a step I'm leaving out? Has this been an issue for anyone else? Can anyone give me a tip on making this work?
Thanks,
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071128/f8826f23/attachment.html
