[mapguide-users] Not much luck with ogr or postgis on Ubuntu
Jo Cook j.cook at OXFORDARCH.CO.UK
Fri Nov 30 08:52:15 EST 2007
Hi All,
I have managed to build MGOS2 on Ubuntu 7.04 with help from Jason's great
instructions on the wiki. However, when I try and make a new data connection
with either postgis or ogr I get errors.
In mapguide studio when I try to make a postgis connection I get the default
feature editor screen and errors in my error log saying
CLNT_8_UNABLE_TO_LOAD_LIBRARY.
When I make an ogr connection I get the proper editor (with data source and
readonly connection options) but I get a connection failed error when I try
and test the connection. The error log says CLNT_4_PROVIDERNOTREGISTERED.
I have tested my connection string with ogrinfo and it works, and I have
checked that both providers are in my providers.xml file.
I have also tested both connection strings with testconnection in the web
tier test suite and both give me the CLNT_4_PROVIDERNOTREGISTERED error.
Has anyone successfully managed to use either of these connectors with
Ubuntu, and how do I begin debugging the problem?
Many thanks
Jo
View this message in context: http://www.nabble.com/Not-much-luck-with-ogr-or-postgis-on-Ubuntu-tf4910839s16610.html#a14059963
