[mapguide-users] MGOS 2 build freezing on Ubuntu 7.10
Mange magnus.ek at boliden.com
Fri Nov 30 14:10:02 EST 2007
Hi guys, I applied the patch (not with curl) by simply adding the missing
lines in the makefile. Now the server is up and running. . .Now I will try
to discover the fusion package. . .
Thanks for the quick response on this ticket!
/Mange
Mange wrote:
> I got as far as you did. The make file crashed on the liblib_json.so.
> I may also mention that I first installed Ubuntu 7.10 64-bit server. Then
> you could not install fdo-3.3.0. So I reinstalled the 32-bit version.
> /Mange
> JasonBirch wrote:
>> Hmm...
>> I just got through building 2517 (mostly) and I think I got farther than
>> you did but then ran into a missing jsoncpp reference:
>> http://trac.osgeo.org/mapguide/ticket/347
>> Jason
>> -----Original Message-----
>> From: Jo Cook
>> Subject: RE: [mapguide-users] MGOS 2 build freezing on Ubuntu 7.10
>> It's revision 2514, updated earlier on today
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/MGOS-2-build-freezing-on-Ubuntu-7.10-tf4881293s16610.html#a14089867
