[mapguide-users] Not much luck with ogr or postgis on Ubuntu
Jason Birch Jason.Birch at nanaimo.ca
Fri Nov 30 19:05:03 EST 2007
Here are the ones from my local Ubuntu build:
  <FeatureProvider>
    <Name>OSGeo.OGR.3.3</Name>
    <DisplayName>OSGeo FDO Provider for OGR</DisplayName>
    <Description>Access to OGR data sources</Description>
    <IsManaged>False</IsManaged>
    <Version>3.3.0.0</Version>
    <FeatureDataObjectsVersion>3.3.0.0</FeatureDataObjectsVersion>
<LibraryPath>/usr/local/fdo-3.3.0/lib/libOGRProvider.so</LibraryPath>
 </FeatureProvider>
 <FeatureProvider>
    <Name>OSGeo.PostGIS.3.3</Name>
    <DisplayName>OSGeo FDO Provider for PostGIS</DisplayName>
    <Description>Read/write access to spatial and attribute data in an
PostGIS.</Description>
<LibraryPath>/usr/local/fdo-3.3.0/lib/libPostGISProvider.so</LibraryPath
  </FeatureProvider>
Both of these are symlinks to the 3.3.0 versions.
Jason
-----Original Message-----
Subject: RE: [mapguide-users] Not much luck with ogr or postgis on
Ubuntu
Could you open providers.xml (should be under your fdo-3.3.0/lib) and
find the entries for the PostGIS and OGR providers, then send us those
snippets?
