[mapguide-users] Not much luck with ogr or postgis on Ubuntu
Jason Birch
Jason.Birch at nanaimo.ca
Fri Nov 30 20:37:10 EST 2007
Last time I tried, I was unable to connect to PostGIS:
http://tinyurl.com/3aew5l
I'm most of the way through a full clean rebuild right now (verifying the previous problem with the CGI agent) and will test once I get up and running again.
Jason
Subject: RE: [mapguide-users] Not much luck with ogr or postgis on Ubuntu
Do you get the same errors as Jo Cook on your build?
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071130/b7422562/attachment.bin
