[mapguide-users] Coordinate Systems
Kenneth, GEOGRAF A/S
ks at geograf.dk
Mon Oct 1 14:58:16 EDT 2007
I agree that it is important. But the problem is that MapGuide Studio
assumes that the server uses the Mentor library.
This means that you should report the problem to Autodesk, as this forum
has no influence on the development of MapGuide Studio.
I usually google around for the EPSG code, and then use the http
interface to get the WKT for the projection.
If all else fails, I use the XY-M projection.
Regards, Kenneth, GEOGRAF A/S
Scott Hameister skrev:
> This is important...several states use county coordinate sytems for
> local govt and other states are looking at adopting them...
> ...If Autodesk Map piublishes using its Definition, and Studio can
> recognize it, but Mapguide Open Source won't, then more and more
> geographic regions of the US will become unreachable, and its likely
> to increase...Nobody wants to reproject all their hard work on every
> layer they publish...Is this going to be addressed in the future..
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
> *Kenneth, GEOGRAF A/S
> *Sent:* Thursday, September 27, 2007 1:58 PM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Coordinate Systems
> I am not 100% on the coordinate systems, but I have not found a way to
> add coordinate systems.
> You can generally use the EPSG code or WKT format for the maps.
> The problem is that you cannot enter these codes in MapGuide Studio.
> You have to change it in the Xml and then load the modified Xml back
> into MapGuide OS.
> If someone has an easier solution, please share :D
> Does anybody have an answer on how to add missing coordinate Systems
> to Open Source 1.2 ....I too have a County Coordinate system In
> Wisconsin I'd like to have Mapguide OS recognize...I'm using Mapguide
> Studio where I can find the system, but it crashes using OS
> server...Where can we enter the codes in OS 1.2 so that the Authored
> Map sees them?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071001/95500363/attachment.html
