[mapguide-users] Ajax Viewer and iFrames in ASP.NET - has anyone perfected this?
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue Oct 2 02:22:58 EDT 2007
I have overridden the "loading" image from javascript. The initial
"mapLoaded" then triggers a call to the server.
This event then means that the map has actually been displayed, and may
be a bit too late, if you are only looking for the "sessionCreated" event.
Regards, Kenneth, GEOGRAF A/S
BruceWeston skrev:
> Hello folks,
> I've been trying to create a 3-iframed web application in .NET, but I'm
> spending quite a bit of time trying to figure out when the AJAX viewer has
> been loaded in my code. I want to do this using my C# code behind instead of
> Javascript. Ideally, I'd like to use a call to a method which would return
> me a definite yes or no, then delay the loading of the iframes until the
> session is firmly established. Any ideas? Someone must have done something
> like this before......
> Thanks in advance!
