[mapguide-users] OSGeo could not be found. ERROR
ales6
ales6 at email.si
Tue Oct 2 03:30:31 EDT 2007
I checked. I have ASP 2.0 on all virtual folders and default authentication
"Windows"
I get this error also if I try to compile C# project including OSGeo
namespace.
Error 2 The type or namespace name 'OSGeo' could not be found (are you
missing a using directive or an assembly reference?)
C:\mapguide\DOTNETVIEWERSAMPLE\UTILITYFUNCTIONS.ASPX 21
Jackie Ng wrote:
> Are the "mapviewernet" and "mapviewerajax" virtual directories set as
> applications and using ASP.net 2.0?
> - Jackie
> ales6 wrote:
>> Having problem with MGOS OSGeo libraray.
>> - I have fresh & clean MapGuide installation v1.2
>> ERR: OSGeo could not be found.
>> Server Error in '/mapguide' Application.
>> Compilation Error
>> Description: An error occurred during the compilation of a resource
>> required to service this request. Please review the following specific
>> error details and modify your source code appropriately.
>> Compiler Error Message: CS0246: The type or namespace name 'OSGeo' could
>> not be found (are you missing a using directive or an assembly
>> reference?)
>> Source Error:
>> Line 21: < %@ Import Namespace="System.Text" % >
>> Line 22: < %@ Import Namespace="System.Globalization" % >
>> Line 23: < %@ Import Namespace="OSGeo.MapGuide" % >
>> Line 24:
>> Line 25: < script runat="server" >
>> ..can anyone help me solve this problem !?
>> thx
View this message in context: http://www.nabble.com/OSGeo-could-not-be-found.-ERROR-tf4547999s16610.html#a12994129
