[mapguide-users] Scripts timing out I think
George McLean
gmclean at gorge.net
Wed Oct 3 18:52:59 EDT 2007
I am using Apache/PHP with MGOS 1.2 querying against MySQL using FDO.
I have a query that returns line entities based on user input to the
query. For each geometry returned, I am creating a line feature on a
temporary line layer. This works well since I can control the color and
line width of the lines indicating the selected items.
My problem is when I get large result sets (~7500 lines) from the query.
It appears that the script never finishes. I get some of the lines I
expect but not all of them. If I turn off the line drawing routine, the
script does finish but of course I get no lines. This leads me to
believe the script is timing out.
Any suggestions on how to do this more efficiently? I am adding insert
commands to a MgFeatureCommandCollection object as I step through the
result set and then updating and saving the updates once after looping
is finished.
Are there settings that would extend how long this script can run?
I looked at the following settings but was not sure what to try and
change. Any suggestions before I start hacking?
Mapguides serverconfig.ini:
ConnectionTimeout = 120
DataConnectionTimeout = 600
SessionTimeout = 120
Apache
Timeout = 300
KeepAliveTimeout = 15
FastCgiConfig -idle-timeout = 120
FastCgiServer -idle-timeout=120
PHP
max_execution_time = 600
Thanks
George McLean
