[mapguide-users] Print temporary layer
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Oct 4 03:26:23 EDT 2007
My best guess is that the layer is not visible in the runtime map.
I have not used the samples, so I can't tell you how to fix it.
Regards, Kenneth, GEOGRAF A/S
Jim O'Leary skrev:
> I have used the phpsamples\custom_output code to print a portion of a map.
> However, I want the image to have a border, so I've used the digitizing
> sample code to put a session layer on the runtime map with a rectangle on
> it. However, when I print the map, it does not print the rectangle. Does the
> MGEnvelope, RenderMap functionality etc only apply to saved features?
> Thanks.
