[mapguide-users] Exmple of Gdal index xml
Jason Birch
Jason.Birch at nanaimo.ca
Thu Oct 4 13:01:06 EDT 2007
Hi Gary,
It should work regardless. PHP is always installed for use by mapadmin,
unless you've done some manual work to uninstall it. The original
version of the app counted on the PHP web viewer config file, but I
believe that I worked around this for the current version so that it
should work if you're using the aspx viewer. If you try it and run into
problems, please let me know.
Jason
-----Original Message-----
Subject: RE: [mapguide-users] Exmple of Gdal index xml
I did spot this page, but for it to work, will I not need the php web
extensions installed? I'm using .net
