[mapguide-users] RE:MapAgent problems resolved
rudy.pavan rudy.pavan at studenti.unipd.it
Tue Oct 9 04:56:09 EDT 2007
Hello Kenneth,
I have completely reinstalled MGOS and now all works fine.
Thanks however for your help.
Rudy
>Another likely cause is that the MapAgent.fcgi or MapAgent.exe is not
>allowed to run.
>You can adjust settings for that under the "Extensions" node in IIS.
>Regards, Kenneth, GEOGRAF A/S
>rudy.pavan skrev:
>Hello Kenneth,
>I have tried your solution,but the problems continue.
>Rudy
>I have seen installations where the FCGI is broken.
>Try using this link instead:
>http://localhost/mapguide/mapagent/mapagent.exe?
>OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=en&RESOURCEID=Librar
>y
>://&TYPE=MapDefinition&DEPTH=-1
>Also, MapGuide EP is using another path:
>http://localhost/mapguide2008/mapagent/mapagent.exe?
>y
