[mapguide-users] problems with config paths in MgOS 1.2
gisnewbie
robert.fuss at gmail.com
Thu Oct 11 07:16:08 EDT 2007
I have installed mapguide open source successfully on windows vista running
iis 7.0. The admin interface of mapguide is working without any problems and
so i could load the Sheboygan.mgp file successfully. I configure the
dotnetviewerexample and got running the ajaxviewer, but there is no map
loaded within the ajax viewer. There are no error messages in log files.
I have also tried running mapagent enumerateResources function and there i
get the following error:
Configuration file "C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapagent../webconfig.ini"
cannot be found or cannot be opened.
cannot be found or cannot be opened. Exception occured in method
MgConfiguration.LoadConfiguration at line 110 in file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\common\foundation\System/Configuration.cpp
pleas help!
gisnewbie
View this message in context: http://www.nabble.com/problems-with-config-paths-in-MgOS-1.2-tf4606575s16610.html#a13153732
