[mapguide-users] problem using mgos 1.2.x on vista and iis7.0
geostarter
martin.sagmeister at gmx.at
Fri Oct 12 16:32:59 EDT 2007
I`ve installed mapguide open source successfully on windows vista running iis
7.0. The admin interface of mapguide is working without any problems and so
i could load the Sheboygan.mgp file successfully. I configure the
dotnetviewerexample and got running the ajaxviewer, but there is no map
loaded within the ajax viewer. There are no error messages in log files.
I have also tried running mapagent enumerateResources function and there i
get the following error:
Configuration file "C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapagent../webconfig.ini"
cannot be found or cannot be opened.
cannot be found or cannot be opened. Exception occured in method
MgConfiguration.LoadConfiguration at line 110 in file
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\common\foundation\System/Configuration.cpp
I cant find where the path is set to this.
Please help
Greets
geostarter
View this message in context: http://www.nabble.com/problem-using-mgos-1.2.x-on-vista-and-iis7.0-tf4599474s16610.html#a13132140
