[mapguide-users] MapGuide Automated Tiling Engine 1.2 -
patchedrelease
Krunoslav
a_krunoslav at gmx.net
Mon Oct 15 01:22:06 EDT 2007
Kori Maleski-4 wrote:
> Are the scales you are using the same as in the Map Definition in Studio?
> If you run it without specify a scale does it throw the same errors?
Of course they are the same: I am running it without any parameter:
C:\Program Files\Websoft Developers\FacilitiesMap Tiling
Engine>FmTilingEngine.e
xe -u Administrator -p admin
Preparing to Tile 'map1' Map Definition...
Initializing Connection to MapGuide...Succeeded
Tiling 'Orto' Layer Group...
Scale: 1:5000 Finite Scale 1 of 3
Tiles: 9 ( 3 Columns x 3 Rows )
...1...2...3...4...5...6...7...8...9 100%
Scale: 1:2000 Finite Scale 2 of 3
Scale: 1:1000 Finite Scale 3 of 3
Tiling Complete
But, as I wrotebefore, tiles are not being made due to Errors. Should I try
to change some parameters regarding tile size and format in
serverconfig.ini?
View this message in context: http://www.nabble.com/MapGuide-Automated-Tiling-Engine-1.2---patched-release-tf4616105s16610.html#a13206887
