[mapguide-users] Re: MG Enterprise and Open-Source in one server
Gary Morin
gary.morin at keynetix.com
Fri Oct 19 07:23:16 EDT 2007
Hi
I also trying to install MGOS and MGE on same machine, I followed tips below
and both services work.
However when I fire up MapGuide administrators both appear to be sharing the
same config settings, if you change a setting for one it changes for the
other. I would have thought this indicates that the two are not working
side by side.
Regards
Gary
> <MG install directory>\Server\Bin\serverconfig.ini and <MG install
> directory>\WebServerExtensions\www\webconfig.ini were the ini files that
> we edited. You have to change the [AdministrativeConnectionProperties],
> [ClientConnectionProperties] and [SiteConnectionProperties] ports in
> these two files for one of the installs.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071019/750fd3e4/attachment.html
