[mapguide-users] Building MGOS 1.2 on Ubuntu Server 7.04
Ray Holtz
ray at rayholtz.com
Fri Oct 19 22:26:44 EDT 2007
Rudy, I have installed it on Ubuntu Server 7.04 last weekend. I used
these directions:
http://wiki.osgeo.org/index.php/Building_Mapguide_on_Ubuntu_7.04_Server
and the only bit it seemed they left out was to install a package named
'build-install'. You can run 'apt-get install build-install' (without
quotes) to get it, otherwise those directions are dead on. I didn't
make any changes to the basic install, just installed from the Ubuntu
7.04 server CD, and started following the directions top to bottom. If
that doesn't work for you, please post some error messages you get and
we will try to help.
Good Luck!
Ray
rudy.pavan wrote:
> Hi,
> I have tried to install MGOS 1.2 on Ubuntu Server 6.06 without
> success,then I have tried on Ubuntu Server 7.04 whit the same results.
> I have followed the guide at
> http://wiki.osgeo.org/index.php/Building_MapGuide_quick_starts_guides.
> The problem is that the MapGuide Server does not installed,if I go
> to /usr/local/mapguideopensource the server folder does not appears.
> Can anyone help me?
> Thanks
> Rudy
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
