Fw: [mapguide-users] Newbie Questions
Kenneth, GEOGRAF A/S
ks at geograf.dk
Wed Oct 24 17:13:42 EDT 2007
Right click the folder, then select "properties", then click "create",
then click "ok".
You should now see the correct icon. You should now be able to change
the configuration.
Regards, Kenneth, GEOGRAF A/S
s r skrev:
> hi
> take a look at this picture. the icon of mapguide is different from
> for example IIShelp, so when i wanna change the configuration , its
> button is inactive in properties. what should i do now?
> ----- Forwarded Message ----
> From: "Kenneth, GEOGRAF A/S" <ks at geograf.dk>
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Sent: Tuesday, October 23, 2007 2:59:22 PM
> Subject: Re: [mapguide-users] Newbie Questions
> You can bump the number of connections on Win XP to 40:
> http://weblogs.asp.net/cazzu/archive/2003/10/10/31476.aspx
> If the MapAdmin is giving error 500, it is usually PHP related.
> Check that the correct path for the php.exe is configured in IIS,
> and also check that the temp directory from php.ini is writeable by
> the IIS account.
> On rare occasions, the "500" errors make it into the system eventlog,
> and further information may be found there.
> Jackie Ng skrev:
>> 1) Are you using Internet Explorer? Try turning off "friendly HTTP errors" so
>> you get a more detailed error message. Also in my experience, I wouldn't
>> recommend using the .net configuration in Windows XP as IIS is totally
>> crippled with a 10 connection limit, this may be a contributing factor.
>> 2) MapGuide 6.5 is the previous version of the MapGuide product. v6.5 and
>> OS/Enterprise are two completely different things.
>> 3) The Developer's Guide that comes with the installation, and the docs on
>> the mapguide osgeo site are the definitive sources (at the moment). Of
>> course you could always ask this list. We're all learning as we go (at least
>> I am) ;-)
>> - Jackie
>> s r-7 wrote:
>>> Hi everyone.
>>> I'm a newcomer and have some problems with MapGuide Open Source:
>>> 1. It sounds there is some problem with Site Administrator. I have
>>> installed both Server and WebServer Extensions (IIS and ASP.Net 2.0) on
>>> Win XP for localhost. When i wanna test installation according to its pdf,
>>> MapAgent and WebServer Extension respond correctly but for Site
>>> Administrator this error will be displayed ' The page cannot be displayed,
>>> HTTP 500'. I don't know how to progress.
>>> 2. I have got also MapGuide v6.5. What's the use of it?
>>> 3. MapGuide Open Source really doesn't have any tuorial?
>>> Thanks
>>> __________________________________________________
>>> Do You Yahoo!?
>>> Tired of spam? Yahoo! Mail has the best spam protection around
>>> http://mail.yahoo.com
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Do You Yahoo!?
Skipped content of type multipart/related
