[mapguide-users] Problems with new fdo ogr build on Ubuntu 6.06
Jo Cook
j.cook at OXFORDARCH.CO.UK
Fri Oct 26 04:50:18 EDT 2007
Hi All,
Having just discovered that the postgis and ogr fdo connectors have been
added to the fdo svn trunk (and therefore been made available to the
standard mapguide build) I thought I would give it a go building on Ubuntu
6.06 as per the instructions on the wiki.
Build_Thirdparty went through without a hitch, all I needed to do was add a
/usr/local/fdo-3.3.0 directory and give it the appropriate ownership.
However, build_linux failed at (I think) the ogr point and I can't really
figure out what the problem is from the build log. The section relating to
the ogr build is as follows:
make[1]: Entering directory `/home/joc/fdosvn/Providers/OGR'
test -z "/usr/local/fdo-3.3.0/lib" || mkdir -p -- "/usr/local/fdo-3.3.0/lib"
/bin/sh ./libtool --mode=install /usr/bin/install -c 'libOGRProvider.la'
'/usr/local/fdo-3.3.0/lib/libOGRProvider.la'
libtool: install: warning: relinking `libOGRProvider.la'
(cd /home/joc/fdosvn/Providers/OGR; /bin/sh ./libtool --tag=CXX
--mode=relink g++ -MMD -MT -D__USE_GNU -DLINUX -DLINUX_IA32 -o
libOGRProvider.la -rpath /usr/local/fdo-3.3.0/lib -shared -release 3.3.0
-L/home/joc/fdosvn/Thirdparty/gdal/lib -L../../Thirdparty/gdal/lib
OgrFdoUtil.lo OgrProvider.lo ProjConverter.lo
../../Fdo/Unmanaged/Src/libFDO.la -lgdal )
g++ -shared -nostdlib
/usr/lib/gcc/i486-linux-gnu/4.0.3/../../../../lib/crti.o
/usr/lib/gcc/i486-linux-gnu/4.0.3/crtbeginS.o .libs/OgrFdoUtil.o
.libs/OgrProvider.o .libs/ProjConverter.o -Wl,--rpath
-Wl,/usr/local/fdo-3.3.0/lib -L/home/joc/fdosvn/Thirdparty/gdal/lib
-L/usr/local/fdo-3.3.0/lib -lFDO -lgdal -L/usr/lib/gcc/i486-linux-gnu/4.0.3
-L/usr/lib/gcc/i486-linux-gnu/4.0.3/../../../../lib
-L/usr/lib/gcc/i486-linux-gnu/4.0.3/../../.. -L/lib/../lib -L/usr/lib/../lib
-lstdc++ -lm -lc -lgcc_s /usr/lib/gcc/i486-linux-gnu/4.0.3/crtendS.o
/usr/lib/gcc/i486-linux-gnu/4.0.3/../../../../lib/crtn.o -Wl,-soname
-Wl,libOGRProvider-3.3.0.so -o .libs/libOGRProvider-3.3.0.so
/usr/bin/install -c .libs/libOGRProvider-3.3.0.soT
/usr/local/fdo-3.3.0/lib/libOGRProvider-3.3.0.so
(cd /usr/local/fdo-3.3.0/lib && { ln -s -f libOGRProvider-3.3.0.so
libOGRProvider.so || { rm -f libOGRProvider.so && ln -s
libOGRProvider-3.3.0.so libOGRProvider.so; }; })
/usr/bin/install -c .libs/libOGRProvider.lai
PATH="$PATH:/sbin" ldconfig -n /usr/local/fdo-3.3.0/lib
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,--rpath -Wl,LIBDIR' linker flag
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
make[1]: Nothing to be done for `install-data-am'.
make[1]: Leaving directory `/home/joc/fdosvn/Providers/OGR'
acinclude.m4:7: warning: underquoted definition of FDO_HELP_STRING
run info '(automake)Extending aclocal'
or see http://sources.redhat.com/automake/automake.html#Extending-aclocal
acinclude.m4:12: warning: underquoted definition of FDO_SUBST
acinclude.m4:19: warning: underquoted definition of FDO_FAST_OUTPUT
acinclude.m4:25: warning: underquoted definition of FDO_GEN_CONFIG_VARS
acinclude.m4:66: warning: underquoted definition of FDO_GENERATE_MAKEFILES
acinclude.m4:73: warning: underquoted definition of FDO_OUTPUT
acinclude.m4:82: warning: underquoted definition of FDO_DEFINE_TYPE_RLIM_T
acinclude.m4:107: warning: underquoted definition of FDO_SUBST_EXPANDED_ARG
acinclude.m4:114: warning: underquoted definition of FDO_EXPORT_ARGUMENTS
Putting files in AC_CONFIG_AUX_DIR, `../..'.
configure.in:66: required file `Doc/Makefile.in' not found
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for bison... bison -y
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries...
yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries...
yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
yes
appending configuration tag "F77" to libtool
configure: Using optimized configuration
configure: creating ./config.status
config.status: error: cannot find input file: Makefile.in
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target `install'. Stop.
joc at ubuntu:~/fdosvn$ exit
So I can see that there is a problem quite early on where it says:
"configure.in:66: required file `Doc/Makefile.in' not found"
But I don't really know what to do about that- so if anyone can give me some
pointers I'd appreciate it greatly.
Many thanks
Jo
PS I will post this on the fdo list if I don't get any replies here but
don't want to double-post if I can avoid it...
View this message in context: http://www.nabble.com/Problems-with-new-fdo-ogr-build-on-Ubuntu-6.06-tf4695940s16610.html#a13423077
