[mapguide-users] Problems with new fdo ogr build on Ubuntu 6.06
Jo Cook j.cook at OXFORDARCH.CO.UK
Fri Oct 26 06:05:46 EDT 2007
In addition I've also noticed that Ubuntu 6.06 comes with g++ 4.03 whereas
the OGR components have been tested with 3.4 and 4.1. I will build a VM
using 7.04 and see if the problem reoccurs...
Jo
Jo Cook wrote:
> Hi,
> Automake --version gives me 1.9.6- this was the version that worked for me
> when I installed MGOS from the svn branch rather than the trunk...
> I will try what you suggest though
> edit: your suggestion just tells me that automake version is 1.9 as well
> Jo
> François Van Der Biest-2 wrote:
>> François Van Der Biest a écrit :
>>> Have you tried: sudo update-*alternatives* --config *automake
>> (without the stars - of course):
>> sudo update-alternatives --config automake
>> F.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Problems-with-new-fdo-ogr-build-on-Ubuntu-6.06-tf4695940s16610.html#a13424190
