[mapguide-users] UpdateFeatures fails with alias
Jim O'Leary joleary.public at gmail.com
Fri Oct 26 19:55:41 EDT 2007
I am using the new alias feature of MapGuide to reference a SHP file on disk
rather than import a copy into the repository with a load procedure. I can
open the SHP and read it okay, but I cannot update a feature in it. The
update does not generate an exception message and does not update the
feature.
I know that my updateFeatures code works because up til now I have been
using a SHP file in the repository and updating the feature successfully.
The selection string is something like:
FeatId = 4
FeatId is a 32Int.
Any suggestions? Can you update a SHP that is on disk, not part of the
repository?
Thanks
View this message in context: http://www.nabble.com/UpdateFeatures-fails-with-alias-tf4700386s16610.html#a13437403
