[mapguide-users] My PHP code under mapguide web app
Maksim Sestic max at geoinova.com
Sat Oct 27 10:40:50 EDT 2007
Huh, now when .php extensions call php-win.exe my script doesn't get parsed
(doesn't reach PHP compiler at all). I'll try playing a little more with
it...
Kenneth, GEOGRAF A/S wrote:
> .php call can be handled directly (without fcgi), by letting .php
> extensions be executed with:
> C:\Program Files\MapGuideOpenSource\WebServerExtensions\Php\php-win.exe
> I don't know why it does not work with .fgci, but I have seen that
> problem before.
> I belive that the development team are trying to remove fgci completely.
> Regards, Kenneth, GEOGRAF A/S
> Maksim Sestic skrev:
>> Hi Jason,
>> I tried with almost identical code. It keeps returning "This page can not
>> be
>> displayed" error. Something's preventing the code to get executed, but I
>> don't know what exactly :-) My IIS web application (under mapguide2008
>> web
>> application branch) enables scripts execution. Is there some specific PHP
>> setting I'm not aware of?
>> Regards,
>> Maksim Sestic
>> JasonBirch wrote:
>>> Is display_errors turned on in your php.ini file?
>>> What are you using for a test .php?  I generally use a file that
>>> contains:
>>> <?php phpinfo(); ?>
>>> Jason
>>> -----Original Message-----
>>> From: Maksim Sestic
>>> Subject: [mapguide-users] My PHP code under mapguide web app
>>> that .php extensions are allowed, poiting to
>>> "..\mapagent\isapi_fcgi.dll". When I try to run test.php script from
>>> client computer it simply won't parse, meaning - nothing happens and no
>>> errors returned.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/My-PHP-code-under-mapguide-web-app-tf4696400s16610.html#a13443772
