[mapguide-users] Strange labels on Ubuntu Linux 7.10
Traian Stanev
traian.stanev at autodesk.com
Mon Oct 29 19:45:25 EDT 2007
OK, then it's likely that MapGuide is not searching the correct places for fonts on Ubuntu Linux.
Consider writing this up in a ticket.
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org on behalf of Jackie Ng
Sent: Mon 10/29/2007 5:58 PM
To: mapguide-users at lists.osgeo.org
Cc:
Subject: RE: [mapguide-users] Strange labels on Ubuntu Linux 7.10
Hi Traian,
Your last suggestion was the cure! Cheers.
- Jackie
Traian Stanev wrote:
> Then I have no idea... As one last check, you can try copying the actual
> Verdana font file to the run directory of the mgserver executable.
> That's where it will search for sure.
> Traian
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
>> bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>> Sent: Monday, October 29, 2007 1:37 AM
>> Hmm, that layer (Districts) defines the font as Verdana, but I already
>> have
>> the Verdana font installed. ??
>> - Jackie
>> > It's likely failing to match the font used for the labels. For
>> example if
>> > it is set to Arial and the Linux box doesn't have that font, it may
>> match
>> > with some other font -- and the matching is not always perfect. One
>> > solution is to install the right fonts on the Linux box, another is
>> to
>> > explicitly specify fonts that are available on Ubuntu in the layer
>> > definition.
>> > Traian
>> Ng
>> > Sent: Sat 10/27/2007 12:34 AM
>> > Cc:
>> > Subject: [mapguide-users] Strange labels on Ubuntu Linux 7.10
>> > Hi List,
>> > I just built mgos 1.2.0 on Ubuntu Linux 7.10, and when I loaded
>> up the
>> > Sheboygan dataset, I get these crazy looking wingding like
>> labels,
>> > instead
>> > of english text. (?)
>> > See attached screenshot
>> > http://www.nabble.com/file/p13439407/sheboygan.jpg
>> > Any ideas what could be wrong?
>> > - Jackie
>> > View this message in context:
>> > http://www.nabble.com/Strange-labels-on-Ubuntu-Linux-7.10-
>> tf4701219s16610.html#a13439407
>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > mapguide-users mailing list
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context: http://www.nabble.com/Strange-labels-on-
>> Ubuntu-Linux-7.10-tf4701219s16610.html#a13461852
View this message in context: http://www.nabble.com/Strange-labels-on-Ubuntu-Linux-7.10-tf4701219s16610.html#a13477770
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071029/6aa89486/attachment.html
