[mapguide-users] Major Feature Join Problems
IT-Joe Marvin
JMarvin at redwoodcity.org
Tue Oct 30 03:19:48 EDT 2007
Okay, so I went ahead wrote my view to a table (select into as suggested) and I fully expected that to resolve the issue. However, my little 9 row table exhibits the exact same behavior. Now I cannot exclude the possibilty that I am doing something wrong here. But I now wonder if we are indeed having the same issue.
Some other things we've noticed while trying to debug this earlier:
- We were able to duplicate this problem in ESRI ArcMap by joining the tables in a certain order.
- When joining the table, selecting an "Inner Join" causes no parcels to be themed. Outer Join has the wacky theme jumping.
-joe
From: mapguide-users-bounces at lists.osgeo.org on behalf of Jason Birch
Sent: Mon 10/29/2007 11:14 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Major Feature Join Problems
Not much comfort in that :)
Have you tried writing your view out as a table (select into) to see if it goes away as it did for Jackie?
I'd be interested in seeing the view definitions... maybe in comments on the new ticket?
Jason
We too are experiencing this problem when joining to a SQL 2000 view using the FDO provided via MG2008 enterprise. In our case, joining a SQL View to a SHP file (imported layer, but not converted to SDF) results in these wacky jumping themes.
At least it seems we are not alone.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071030/a6d2d9fb/attachment.bin
