[mapguide-users] Invoke URL in MapGuide Studio
Andrew DeMerchant andrew.demerchant at gemtec.ca
Tue Oct 30 08:15:09 EDT 2007
In Studio, check the "Additional Parameters" for the Invoke URL
command...it's on the same tab as where you enter your url. Do you have
both of those layers entered in the "use only these layers" field?
Andrew
alba wrote:
> Hi all,
> in MapGuide Studio I have a URL to invoke as:
> http://www.nabble.com/file/p13483981/invoke.jpg
> when I use one layer ex. MONUMENTI the command is abled when I select a
> object on layer MOMUNEMTI,
> but I use two layers, as image, the command is disabled when I select a
> object on layer MOMUNEMTI or ZONE DI PIANO.
> why?
> thank Alba
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
