[mapguide-users] Making Temporary Markups
Kenneth, GEOGRAF A/S
ks at geograf.dk
Wed Oct 31 03:39:39 EDT 2007
When you save or access a resource, you use
"Library://<folder>/<resource>.<ext>".
To make the resource temporary, use
"Session:<sessionid>//<folder>/<resource>.<ext>".
So, to modify the code, search for "Library://" and determine if that
particular access is supposed to be temporary, and change as note above.
Regards, Kenneth, GEOGRAF A/S
Denis Lalonde skrev:
> Is there sample code for creating map markups/redlining that are saved
> to the session only and not directly to the Library in Repositories?
> Alternatively, can someone point me in the right direction as to what
> to change in the Shareable Markup Sample site (
> http://data.mapguide.com/mapguide/gt/index.php) so that I can create a
> temporary layer rather than one of the permanent layers listed in the
> "Available Markup" combo-box?
> Thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20071031/be6ce098/attachment.html
