[mapguide-users] Connecting to remote files using mapagent ?
Kenneth, GEOGRAF A/S
ks at geograf.dk
Sun Sep 2 10:54:13 EDT 2007
Your MapGuide Server, runs under a "Local System Account".
You can change the account, from the "Control Panel" -> "Administrative
Tools" -> "Services" application.
Beware that you will most likely have to set up local permissions on the
MapGuide folders if you change the account for the service.
Alternatively, the local system account from the MapGuide Server
machine, must have read access to the shared folder.
I'm not sure how to acomplish this, since the mapguide server uses the
"Local System Account", and thus does not have a shared domain with the
server hosting the files.
If you are unconserned with security, you might set up the share to
allow "Guest" access.
Regards, Kenneth, GEOGRAF A/S
Mansoureh Sadrykia skrev:
> Hi James Card and thanks for your reply,
> I have tried UNC path(\\192.168.0.51\ <file://%5C%5C192.168.0.51%5C>)
> in my xml too, but the same error remains. Shall I change something in
> my mg site administrator to be able to access files over a LAN or ....?
> Thanks in Advance,
> */James Card <James.Card at calcad.com>/* wrote:
> On Sat, 01 Sep 2007 06:48:37 -0700, Mansoureh Sadrykia
> wrote:
> > I try to access to a folder of shp files in a LAN. I defined the
> > directory of my SHPs - which are shared in the network- in my xml
> > content as %MG_DATA_PATH_ALIAS[san-diego]%, in which san-diego
> is alias
> > and the path is \\192.168.0.51\San Diego. (192.168.0.51 is IP
> address of
> > my computer).
> > When I try to access this feature source an error occures which
> says
> > "the feature source is invalid, an exception occured in FDO
> component.
> > The directory does not exist". I don't know how I should get
> permissions
> > to read the remote data stores.
> We typically don't use the "%MG_DATA_PATH_ALIAS[san-diego]%"
> syntax when
> running unmanaged FeatureSources on our MGOS servers; we just put
> in the
> UNC path "\\192.168.0.51\San Diego" (by the way, I'd avoid paths
> containing SPACE characters -- still bad juju for Windows machines).
> James Card
> 209-578-5580
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> Take the Internet to Go: Yahoo!Go puts the Internet in your pocket:
> <http://us.rd.yahoo.com/evt=48253/*http://mobile.yahoo.com/go?refer=1GNXIC>
> mail, news, photos & more.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070902/7fe439fb/attachment.html
