[mapguide-users] Annotation from ESRI Geodatabase?
Brad Nesom kidsmake6 at msn.com
Tue Sep 4 21:58:47 EDT 2007
Ben,
There are quite a few options depending upon the tools you have.
1. The annotation can be exported from the pgdb as a shape.
2. you can use fme to export the pgdb as about any format you can think of.
3. not sure there is a prcess that will do any good but for what it is
worth.
http://support.esri.com/index.cfm?fa=downloads.patchesServicePacks.viewPatch
&PID=66&MetaID=1330#install-s
Or for 9.1
&PID=19&MetaID=1143
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ben_D
Sent: Tuesday, September 04, 2007 4:07 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Annotation from ESRI Geodatabase?
Does anyone know if it is possible to connect to an ESRI personal
geodatabase and pull annotation out of it? If not - does anyone know a work
around?
I've searched the forums without much luck.
Thanks!
View this message in context:
http://www.nabble.com/Annotation-from-ESRI-Geodatabase--tf4380299s16610.html
#a12486636
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
