[mapguide-users] Properties Pane doesn't update when selecting
from task pane
Jackie Ng
jackie.ng at aecsystems.com.au
Wed Sep 5 01:16:26 EDT 2007
When you do a selection from the viewer, it does two things.
1 - Request a map image with the selection.
2 - Queries the feature information for that selection and displays it in
the property pane.
When you programmatically select, it only does 1 and not 2.
You'll have to query the feature information of the selected polygon(s). Get
a reference to the property pane and call SetProperties() passing in your
feature information. The viewer does this on the client side (ie. through
javascript)
- Jackie
Col P wrote:
> I have modified selectfeatures.php, from the DEvGuide sample application,
> and only layer names etc have been changed to make it work with my data
> and to select a single fetaure. All works OK, feature is correctly
> selected, correctly highlights in the map window. However, the Properties
> pane goes blank and will only show information on features selected
> manually. Have used exactly the same code as in the Devguide sample
> application. I modified that sample code (selectfeatures.php) to return
> only one Parcel in the Sheboygan data and it behaves properly. Am I
> missing something here?:confused:
View this message in context: http://www.nabble.com/Properties-Pane-doesn%27t-update-when-selecting-from-task-pane-tf4345757s16610.html#a12491749
