[mapguide-users] Cartographicsymbolsproblems
Stefan Dalakov s.dalakov at mapware.net
Wed Sep 5 07:55:27 EDT 2007
I seem to have reached the top level of psychical disorder - I answer my
own posts. Anyway .. Traian  was right - I found a workaround for this
problem (N:1) - massages usually relief the situation. I will add the
working SymbolDef to the ticket - don't know if this is the correct way
to proceed .
Stefan Dalakov
Stefan Dalakov wrote:
> I created 2 tickets for these 2 bugs, with screenshots and
> symboldefinitions. Hope it would help.
> I use 1.2.0 RC2. without any patches, on Win XP, IIS and PHP as dev
> environment, AJAX viewer
> Stefan Dalakov
> Traian Stanev wrote:
>> Yes it would help to get the underlying SymbolDef xml. Sometimes it
>> is possible to massage those to work around some of the bugs. This is
>> particularly true in the case of line styles.
>> Traian
>>     -----Original Message-----
>>     *From:* mapguide-users-bounces at lists.osgeo.org on behalf of Jason
>>     Birch
>>     *Sent:* Tue 9/4/2007 1:25 PM
>>     *To:* MapGuide Users Mail List
>>     *Cc:*
>>     *Subject:* RE: [mapguide-users] Cartographicsymbolsproblems
>>     Hi Stefan,
>>     See below response from Walt (developer / style guru)
>>     For numbers 1 and 2, if you could put together reproducible test
>>     cases
>>     and submit as bugs, that would be great.  This process is documented
>>     here:
>>     http://trac.osgeo.org/mapguide/wiki/SubmitTicket
>>     Jason
>>     From: Walt Welton-Lair
>>     Subject: RE: [mapguide-internals] FW: [mapguide-users]
>>     Well, line styles with the new symbolization are not yet officially
>>     supported (i.e. there are bugs)  You're right though - nice to see
>>     someone looking at this.
>>     1 & 2 most likely bugs
>>     3. All properties, including line thickness, are in millimeters.  You
>>     won't see much difference between 0.12mm and 0.25mm - both
>>     probably one
>>     pixel.
>>     4. This gives you a circle (using two arcs):
>>             <Geometry>M -1,0 A 1,1 0 1 1 1,0 A 1,1 0 1 1 -1,0</Geometry>
>>         Here's what the parameters mean:
>>             - move to (-1,0)
>>             - arc to #1 (lower half of circle)
>>                 x/y radii (1,1)
>>                 x-axis rotation in degrees (0)
>>                 use a large arc sweep (1)
>>                 draw clockwise (1)
>>                 end point (1,0)
>>             - arc to #2 (lower half of circle)
>>     5. This will eventually be supported
>>     Walt
>>     From: Jason Birch
>>     Sent: Tuesday, September 04, 2007 6:03 PM
>>     To: MapGuide Internals Mail List
>>     Subject: [mapguide-internals] FW: [mapguide-users] Cartographic
>>     symbolsproblems
>>     Any of you have any insight into this one?  Cool to see someone
>>     trying
>>     to use the new symbol stuff...
>>     From: Stefan Dalakov
>>     Subject: [mapguide-users] Cartographic symbols problems
>>     Hi all,
>>     I have some problems with complex line styles. If anyone can help
>>     with
>>     information, a workaround or at least with information if this is a
>>     known problem.
>>     1. When placing symbols along a line there are problems in displaying
>>     them. See attached screenshots.
>>     2. When selecting a feature with such styling only symbols are
>>     marked as
>>     selected, not the main line. I tried changing the order in the
>>     definition, but this does not help.
>>     3. Line thickness on screen changes incorrectly. If there are 2 lines
>>     with width 0.12 and 0.25, they are displayed with same thickness,
>>     next
>>     visibly different line is with 1.25 and is very thick.
>>     4. How to draw a circle - I could not find a document with
>>     description
>>     of parameters  of A (arc to)  option ?
>>     5. Is there a way to place symbols only at vertices of a line - I
>>     need a
>>     simple, solid line with a circle at every vertex?
>>     Thank you in advance
>>     Stefan Dalakov
>>     _______________________________________________
>>     mapguide-users mailing list
>>     mapguide-users at lists.osgeo.org
>>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070905/b22ca2e0/attachment.html
