[mapguide-users] MG studio 2007 can't cooperate with MG opensource 1.2.0 ? Update of Autodesk.MapGuide.Studio.Site.dll is not enough?
Kenneth, GEOGRAF A/S ks at geograf.dk
Sun Sep 9 05:37:27 EDT 2007
You should NOT copy any of the FDO files into the studio folders.
The FDO folder in the Studio installation is only used with som internal
studio operations, and has no effect on the server's FDO capabilities.
You must modify the providers.xml file that is located in the mapguide
folder (C:\program files\mapguideopensource\server\bin\fdo)
After modifying the file, you must restart the mapguide service.
Studio caches the providers, so you must restart studio as well.
In your case, I would recommend uninstalling Studio, and repeating the
install/patch procedure.
Regards, Kenneth, GEOGRAF A/S
Carl skrev:
> I just had installed MG opensource 1.2, and patched autodesk mg studio 2007
> accordingly (Initial Installation + SP1 + SP1a +
> Autodesk.MapGuide.Studio.Site.dll Patch). I also copied all files located in
> the bin/fdo of mg Opensource 1.2 server to FDO directory of studio 2007 and
> modified the providers.xml. But when new a load procedure or a data
> connection, the shown list are still the previous items, no any provider in
> the providers.xml is listed.
> Now the studio can only deal with previously existing data, layer and
> layout. once to load or connect new data source, the problem would be popup,
> 'Unable to complete request to site','An exception occurred in FDO
> component. Failed to open ArcSDE connection. ', and so on,  Except that DWF
> can be loaded.
> The studio can worked very well with the MG OS 1.1 before, is it not
> compatible with MG OS 1.2 ? or it need much more patches?
> please help me. thank you very much. Now I am urgently waiting to dealing
> with new map data.
