[mapguide-users] MG studio 2007 can't cooperate with MG opensource 1.2.0 ? Update of Autodesk.MapGuide.Studio.Site.dll is not enough?
Stefan Dalakov s.dalakov at mapware.net
Sun Sep 9 15:47:45 EDT 2007
About dete.exe
Some time ago there were problems with Mapguide(6.5) and Civil 3D. Also
had problem like yours with Mapguide OS running on a machine with Map 3D
2008. I guess it is due to the sequence of installations - I think you
should install Map 3D(or the product from which Dete is) first and then
Mapguide.
Carl wrote:
> I found also the error copying the fdo files. I reinstalled the MG studio and
> patchit accordingly, and copy the client library of ArcSDE92 to FDO
> directory.
> Now the studio can load most types of data files except DWG (It seems
> something is wrong with Autodesk Dete.exe. I looked from website of
> autodesk, but not get to a solution). A new problem is : I can't connect to
> arcsde92 installed on local machine. Then i try to connect arcsde92 on
> another machine. Ok. it works. but no featureclass inside the ArcSDE server
> can be listed out. so no real featuresource can be made. In conclude, there
> are two strange phenomena : one is about autodesk dete.exe, and another is
> about the ArcSDE 9.2.
> Regards. SHE
> Kenneth, GEOGRAF A/S wrote:
>> You should NOT copy any of the FDO files into the studio folders.
>> The FDO folder in the Studio installation is only used with som internal
>> studio operations, and has no effect on the server's FDO capabilities.
>> You must modify the providers.xml file that is located in the mapguide
>> folder (C:\program files\mapguideopensource\server\bin\fdo)
>> After modifying the file, you must restart the mapguide service.
>> Studio caches the providers, so you must restart studio as well.
>> In your case, I would recommend uninstalling Studio, and repeating the
>> install/patch procedure.
>> Regards, Kenneth, GEOGRAF A/S
>> Carl skrev:
>>> I just had installed MG opensource 1.2, and patched autodesk mg studio
>>> 2007
>>> accordingly (Initial Installation + SP1 + SP1a +
>>> Autodesk.MapGuide.Studio.Site.dll Patch). I also copied all files located
>>> in
>>> the bin/fdo of mg Opensource 1.2 server to FDO directory of studio 2007
>>> and
>>> modified the providers.xml. But when new a load procedure or a data
>>> connection, the shown list are still the previous items, no any provider
>>> in
>>> the providers.xml is listed.
>>> Now the studio can only deal with previously existing data, layer and
>>> layout. once to load or connect new data source, the problem would be
>>> popup,
>>> 'Unable to complete request to site','An exception occurred in FDO
>>> component. Failed to open ArcSDE connection. ', and so on,  Except that
>>> DWF
>>> can be loaded.
>>> The studio can worked very well with the MG OS 1.1 before, is it not
>>> compatible with MG OS 1.2 ? or it need much more patches?
>>> please help me. thank you very much. Now I am urgently waiting to dealing
>>> with new map data.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070909/eda6378f/attachment.html
