[mapguide-users] MG studio 2007 can't cooperate with MG
opensource 1.2.0 ? Update of Autodesk.MapGuide.Studio.Site.dll
is not enough?
Francisco Javier Rojas Durán
francisco.rojas at dasoft.com.mx
Sun Sep 9 23:23:42 EDT 2007
Hi Everyone:
I see that several people have some several issues using MGOS 1.2.x (since
Beta 1 to Final Version) with MapGuide Studio 2007.
I must point out that THE MAPGUIDE STUDIO Version WICH MATCHES WITH MAPGUIDE
OPENSOURCE 1.1.x - 1.2.x TECHNOLOGY is the all brand new Adsk MapGuide
Studio 2008.
Since MapGuide Studio 2007 works with FDO 3.0.x - 3.1.x , Map 3D 2007 ,
MapGuide Enterprise 2007 and also MGOS 1.0.x and MGOS 1.1 (with workaround)
IS NOT RECOMMENDED TO USE WITH THE NEWER TECHONOLOGY also known as
MapGuideEnteprise 2008 / MGOS 1.2.
You should contact your local Autodesk Reseller, for a trial version of
MapGuide Studio or purchase an Adsk MapGuide Studio 2008 for 500 USD approx.
Regards
Francisco Javier Rojas Duran
Geospatial Consultant & Oracle Specialist
Grupo DaSoft SA de CV
Autodesk Developer Network Member
+52 (55) 52643977
Date: Sun, 09 Sep 2007 13:09:29 +0200
Subject: Re: [mapguide-users] MG studio 2007 can't cooperate with MG
is not
enough?
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Message-ID: <46E3D469.30801 at geograf.dk>
Content-Type: text/plain; charset="iso-8859-1"
I have no experince with the ArcSDE provider, but what I do know is that
the server must have the client files avalible.
The client files should be placed in the FDO folder of the server
(C:\program files\mapguideopensource\server\bin\fdo), or referenced by
the PATH environment variable.
The "autodesk dete.exe" is not part of MapGuide Open Source, so might
not get any response on that topic from this list.
If your problem is only related to Studio. you can Autodesk directly.
Regards, Kenneth, GEOGRAF A/S
Carl skrev:
> I found also the error copying the fdo files. I reinstalled the MG studio
and
> patchit accordingly, and copy the client library of ArcSDE92 to FDO
> directory.
> Now the studio can load most types of data files except DWG (It seems
> something is wrong with Autodesk Dete.exe. I looked from website of
> autodesk, but not get to a solution). A new problem is : I can't connect
to
> arcsde92 installed on local machine. Then i try to connect arcsde92 on
> another machine. Ok. it works. but no featureclass inside the ArcSDE
server
> can be listed out. so no real featuresource can be made. In conclude,
there
> are two strange phenomena : one is about autodesk dete.exe, and another is
> about the ArcSDE 9.2.
> Regards. SHE
> Kenneth, GEOGRAF A/S wrote:
>> You should NOT copy any of the FDO files into the studio folders.
>> The FDO folder in the Studio installation is only used with som internal
>> studio operations, and has no effect on the server's FDO capabilities.
>> You must modify the providers.xml file that is located in the mapguide
>> folder (C:\program files\mapguideopensource\server\bin\fdo)
>> After modifying the file, you must restart the mapguide service.
>> Studio caches the providers, so you must restart studio as well.
>> In your case, I would recommend uninstalling Studio, and repeating the
>> install/patch procedure.
>> Carl skrev:
>>> I just had installed MG opensource 1.2, and patched autodesk mg studio
>>> 2007
>>> accordingly (Initial Installation + SP1 + SP1a +
>>> Autodesk.MapGuide.Studio.Site.dll Patch). I also copied all files
located
>>> in
>>> the bin/fdo of mg Opensource 1.2 server to FDO directory of studio 2007
>>> and
>>> modified the providers.xml. But when new a load procedure or a data
>>> connection, the shown list are still the previous items, no any provider
>>> in
>>> the providers.xml is listed.
>>> Now the studio can only deal with previously existing data, layer and
>>> layout. once to load or connect new data source, the problem would be
>>> popup,
>>> 'Unable to complete request to site','An exception occurred in FDO
>>> component. Failed to open ArcSDE connection. ', and so on, Except that
>>> DWF
>>> can be loaded.
>>> The studio can worked very well with the MG OS 1.1 before, is it not
>>> compatible with MG OS 1.2 ? or it need much more patches?
>>> please help me. thank you very much. Now I am urgently waiting to
dealing
>>> with new map data.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL:
http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070909/d73d5b5
4/attachment-0001.html
