[mapguide-users] MG studio 2007 can't cooperate with MG
opensource 1.2.0 ? Update of Autodesk.MapGuide.Studio.Site.dll
is not enough?
didit.s banuardi.n
didithoe at gmail.com
Sun Sep 9 23:32:13 EDT 2007
for me...
MapGuide Studio 2007 works fine with MGOS 1.2.0.
install the the service pack and replace/patch the "
Autodesk.MapGuide.Studio.Site.dll" file is really a good solution...
upgrading to MGS 2008 is not in my budget now. :-)
br,
didit
gis dev
On 9/10/07, Francisco Javier Rojas Durán <francisco.rojas at dasoft.com.mx>
wrote:
> Hi Everyone:
> I see that several people have some several issues using MGOS 1.2.x (since
> Beta 1 to Final Version) with MapGuide Studio 2007.
> I must point out that THE MAPGUIDE STUDIO Version WICH MATCHES WITH
> MAPGUIDE
> OPENSOURCE 1.1.x - 1.2.x TECHNOLOGY is the all brand new Adsk MapGuide
> Studio 2008.
> Since MapGuide Studio 2007 works with FDO 3.0.x - 3.1.x , Map 3D 2007 ,
> MapGuide Enterprise 2007 and also MGOS 1.0.x and MGOS 1.1 (with
> workaround)
> IS NOT RECOMMENDED TO USE WITH THE NEWER TECHONOLOGY also known as
> MapGuideEnteprise 2008 / MGOS 1.2.
> You should contact your local Autodesk Reseller, for a trial version of
> MapGuide Studio or purchase an Adsk MapGuide Studio 2008 for 500 USD
> approx.
> Regards
> Francisco Javier Rojas Duran
> Geospatial Consultant & Oracle Specialist
> Grupo DaSoft SA de CV
> Autodesk Developer Network Member
> +52 (55) 52643977
> Date: Sun, 09 Sep 2007 13:09:29 +0200
> From: "Kenneth, GEOGRAF A/S" <ks at geograf.dk>
> Subject: Re: [mapguide-users] MG studio 2007 can't cooperate with MG
> is not
> enough?
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Message-ID: <46E3D469.30801 at geograf.dk>
> Content-Type: text/plain; charset="iso-8859-1"
> I have no experince with the ArcSDE provider, but what I do know is that
> the server must have the client files avalible.
> The client files should be placed in the FDO folder of the server
> (C:\program files\mapguideopensource\server\bin\fdo), or referenced by
> the PATH environment variable.
> The "autodesk dete.exe" is not part of MapGuide Open Source, so might
> not get any response on that topic from this list.
> If your problem is only related to Studio. you can Autodesk directly.
> Regards, Kenneth, GEOGRAF A/S
> Carl skrev:
> > I found also the error copying the fdo files. I reinstalled the MG
> studio
> and
> > patchit accordingly, and copy the client library of ArcSDE92 to FDO
> > directory.
> > Now the studio can load most types of data files except DWG (It seems
> > something is wrong with Autodesk Dete.exe. I looked from website of
> > autodesk, but not get to a solution). A new problem is : I can't connect
> to
> > arcsde92 installed on local machine. Then i try to connect arcsde92 on
> > another machine. Ok. it works. but no featureclass inside the ArcSDE
> server
> > can be listed out. so no real featuresource can be made. In conclude,
> there
> > are two strange phenomena : one is about autodesk dete.exe, and another
> is
> > about the ArcSDE 9.2.
> > Regards. SHE
> > Kenneth, GEOGRAF A/S wrote:
> >> You should NOT copy any of the FDO files into the studio folders.
> >> The FDO folder in the Studio installation is only used with som
> internal
> >> studio operations, and has no effect on the server's FDO capabilities.
> >> You must modify the providers.xml file that is located in the mapguide
> >> folder (C:\program files\mapguideopensource\server\bin\fdo)
> >> After modifying the file, you must restart the mapguide service.
> >> Studio caches the providers, so you must restart studio as well.
> >> In your case, I would recommend uninstalling Studio, and repeating the
> >> install/patch procedure.
> >> Carl skrev:
> >>> I just had installed MG opensource 1.2, and patched autodesk mg studio
> >>> 2007
> >>> accordingly (Initial Installation + SP1 + SP1a +
> >>> Autodesk.MapGuide.Studio.Site.dll Patch). I also copied all files
> located
> >>> in
> >>> the bin/fdo of mg Opensource 1.2 server to FDO directory of studio
> 2007
> >>> and
> >>> modified the providers.xml. But when new a load procedure or a data
> >>> connection, the shown list are still the previous items, no any
> provider
> >>> in
> >>> the providers.xml is listed.
> >>> Now the studio can only deal with previously existing data, layer and
> >>> layout. once to load or connect new data source, the problem would be
> >>> popup,
> >>> 'Unable to complete request to site','An exception occurred in FDO
> >>> component. Failed to open ArcSDE connection. ', and so on, Except
> that
> >>> DWF
> >>> can be loaded.
> >>> The studio can worked very well with the MG OS 1.1 before, is it not
> >>> compatible with MG OS 1.2 ? or it need much more patches?
> >>> please help me. thank you very much. Now I am urgently waiting to
> dealing
> >>> with new map data.
> >> _______________________________________________
> >> mapguide-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070909/d73d5b5
> 4/attachment-0001.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070910/8d33fe25/attachment.html
