[mapguide-users] MG studio 2007 can't cooperate with MG
opensource 1.2.0 ? Update of Autodesk.MapGuide.Studio.Site.dll is not
enough?
Carl
carlshe at 163.com
Sun Sep 9 23:46:45 EDT 2007
Thank you all.
Today I open MG studio again and found that I can visit ArcSDE92. It's a bit
strange. I can't know why. I had also restarted my pc many times before. OK.
Now only one problem left, i.e. about the 'asdk Dete'. I will contact the
seller to solve this problem. once get a solution, I will post here.
Kenneth, GEOGRAF A/S wrote:
> I have no experince with the ArcSDE provider, but what I do know is that
> the server must have the client files avalible.
> The client files should be placed in the FDO folder of the server
> (C:\program files\mapguideopensource\server\bin\fdo), or referenced by
> the PATH environment variable.
> The "autodesk dete.exe" is not part of MapGuide Open Source, so might
> not get any response on that topic from this list.
> If your problem is only related to Studio. you can Autodesk directly.
> Regards, Kenneth, GEOGRAF A/S
> Carl skrev:
>> I found also the error copying the fdo files. I reinstalled the MG studio
>> and
>> patchit accordingly, and copy the client library of ArcSDE92 to FDO
>> directory.
>> Now the studio can load most types of data files except DWG (It seems
>> something is wrong with Autodesk Dete.exe. I looked from website of
>> autodesk, but not get to a solution). A new problem is : I can't connect
>> to
>> arcsde92 installed on local machine. Then i try to connect arcsde92 on
>> another machine. Ok. it works. but no featureclass inside the ArcSDE
>> server
>> can be listed out. so no real featuresource can be made. In conclude,
>> there
>> are two strange phenomena : one is about autodesk dete.exe, and another
>> is
>> about the ArcSDE 9.2.
>> Regards. SHE
>>> You should NOT copy any of the FDO files into the studio folders.
>>> The FDO folder in the Studio installation is only used with som internal
>>> studio operations, and has no effect on the server's FDO capabilities.
>>> You must modify the providers.xml file that is located in the mapguide
>>> folder (C:\program files\mapguideopensource\server\bin\fdo)
>>> After modifying the file, you must restart the mapguide service.
>>> Studio caches the providers, so you must restart studio as well.
>>> In your case, I would recommend uninstalling Studio, and repeating the
>>> install/patch procedure.
>>> Carl skrev:
>>>> I just had installed MG opensource 1.2, and patched autodesk mg studio
>>>> 2007
>>>> accordingly (Initial Installation + SP1 + SP1a +
>>>> Autodesk.MapGuide.Studio.Site.dll Patch). I also copied all files
>>>> located
>>>> in
>>>> the bin/fdo of mg Opensource 1.2 server to FDO directory of studio 2007
>>>> and
>>>> modified the providers.xml. But when new a load procedure or a data
>>>> connection, the shown list are still the previous items, no any
>>>> provider
>>>> in
>>>> the providers.xml is listed.
>>>> Now the studio can only deal with previously existing data, layer and
>>>> layout. once to load or connect new data source, the problem would be
>>>> popup,
>>>> 'Unable to complete request to site','An exception occurred in FDO
>>>> component. Failed to open ArcSDE connection. ', and so on, Except that
>>>> DWF
>>>> can be loaded.
>>>> The studio can worked very well with the MG OS 1.1 before, is it not
>>>> compatible with MG OS 1.2 ? or it need much more patches?
>>>> please help me. thank you very much. Now I am urgently waiting to
>>>> dealing
>>>> with new map data.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/MG-studio-2007-can%27t-cooperate-with-MG-opensource-1.2.0---Update-of-Autodesk.MapGuide.Studio.Site.dll-is-not-enough--tf4406674s16610.html#a12586289
