[mapguide-users] initial map scale problem
Nimrod Cnaan nimcnaan at hotmail.com
Mon Sep 10 11:49:53 EDT 2007
you can try changing your server Data cache size to reduce round-trip loading. go to
Site Administrator >> Feature Service >> Data cache size: 300.
> Date: Thu, 6 Sep 2007 17:15:33 -0700> From: jackie.ng at aecsystems.com.au> To: mapguide-users at lists.osgeo.org> Subject: Re: [mapguide-users] initial map scale problem> > > I made a trac ticket for this some time ago.> > http://trac.osgeo.org/mapguide/ticket/155> > Perhaps, you could add some extra information.> > - Jackie> > > alucas wrote:> > > > Hello,> > > > When inital map is loaded, only with IE, sometimes the initial zoomscale> > is the minimun value (0.001) as you can see in the next image:> > > > http://www.nabble.com/file/p10055769/error.JPG > > > > -- > View this message in context: http://www.nabble.com/initial-map-scale-problem-tf3600094s16610.html#a12533835> Sent from the MapGuide Users mailing list archive at Nabble.com.> > _______________________________________________> mapguide-users mailing list> mapguide-users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/mapguide-users
_________________________________________________________________
Explore the seven wonders of the world
http://search.msn.com/results.aspx?q=7+wonders+world&mkt=en-US&form=QBRE
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070910/0fdd0940/attachment.html
