[mapguide-users] Help on Saving my Finished MAP
Carl carlshe at 163.com
Wed Sep 12 00:25:10 EDT 2007
you can package your design with
http://localhost/mapguide/mapadmin/login.php
http://localhost/mapguide/mapadmin/packagemanagement.php
-->Manage Packages
    1. Make Package as a file
             1)Login as Administrator/admin, or other account
             2)click 'Manage Packages' on the left side
             3)you can find the text box with label : "Folder name (e.g.
Library://<root_folder>/<folder1>):"
                       just  enter the folder you want to package
            4)and also you can find the text box with label: "Resulting
package name:"
                       you can use the default name after you enter the
folder library path
            5)and then click 'Make' Button
            6)this process will generate a file with extension '.mgp' inside
your destination installation of MG OS /Server/Packages , such as C:\Program
Files\MapGuideOpenSource\Server\Packages.
    2. copy the file to the package directory of your destination
              copy the generated file from your local package folder to your
    3.
        1)http://destination-localhost/mapguide/mapadmin/login.php
2)http://destination-localhost/mapguide/mapadmin/packagemanagement.php
        login and the enter the page for manage packages of your destination
machine
               you will find the copied file listed out bottom.
        3) choose the copied file and click 'load package'.
                ok.....
sweetGemini wrote:
> thanks for the reply carl, but how can i make a package as a file? sorry
> for the simple question im only a newbie here, please help me, thank you
> again...
View this message in context: http://www.nabble.com/Help-on-Saving-my-Finished-MAP-tf4420647s16610.html#a12628460
